3 Plate clutch mod
  • 3 Plate clutch mod
    Hello, I will be getting the barnett carbon fiber clutch kit as well as the pressure plate spring conversion.
    what I need to know is will I need anything else to do the 3 plate mod on my clutch pack. Thank you in advance
      Had to look it up myself.
    I tried to search for it but couldn't find it. Thank you
      Your welcome.
    Much better off using Yamaha OEM clutch discs and Steals and not the Kevlar from Barnett. Absolutely positively no need for Kevlar on a Roadstar even if it had all the power adders you could throw at it. The spring conversion Part is very nice
      Changed my clutch plates prior to COVID using Yamaha OEM pressure plate and clutch plates. I like the friction zone with Yamaha OEM pressure plate on my 2006 vs the Barnet clutch on my 2003. The Barnett is less forgiving if you are into slow riding in parking lots, but it is an excellent clutch nonetheless. The 2003 has a big bore kit and more torque than the 2006. Due to the extra torque the original owner choose Barnett. I was too aggressive with the 2003 and ruined 5th gear.. woops. I say personal preferance. I have zero issues with oem.
      • DEEPHATE
        DEEPHATE commented
        Maybe I don't want to install the Barnett if it changes the friction zone very much?
      • FDRUCaptain
        FDRUCaptain commented
        I didn’t notice a difference in friction zone when I changed mine. Just slightly stiffer.
      drums , what do u mean by less forgiving, like clunky , or just slams like a detroit locker?
      • drumsonly2002
        drumsonly2002 commented
        The Barnett on my 03 has a smaller friction zone. And when the clutch grabs it is very direct. Great for holeshots, but takes more skill to use in parking lot slow riding.
      I have Barnett kevlar disc's in my vstar/sidecar bike... Sucks for feel.... Like an on-off switch
      • FDRUCaptain
        That was a Vstar thing though wasn’t it? That’s why they made the adjustable lever for them that could be bought?
      • drumsonly2002
        At one point in time 7 years ago, I had a V Star and Road Star. The road Srat clutch way easier than the V Star. You are correct the V Star is akin to an on off switch.
      Sounds like when I raced dirt track. We used a small triple disk clutch. There was no slipping it. It was either engaged or disengaged. So basically you just rev'd it up and dumped the clutch.
        These bikes don't produce enough power to do a 2 or 3 plate mod. If you have any concern the heavy duty green springs are more then enough to handle anything these bikes can give it even in a modified engine. I used the green springs on mine with the big bore engine and there is no way it is gonna slip. But if you think you need it watch the video, But unlike the guy in the video that installed out of the box 'DRY" new disc, soak the new disc in oil before installation. I personally think it is a waste of time and money.
          Any one in michigan have 3 factory friction plates that I can buy
            Lol, I would take Dave's advice, just saying he knows what he is talking about, Do some folks still use SLICK 50 ?
          did the Barnet pressure plate only convertion on my 2004 RS at the weekend, the clutch was just about slipping in top gear, now it's stopped any kind of slipping but not as smooth as OEM . The only other part needed was the housing gasket
          • Mike383
            Mike383 commented
            My plates are toast near metal to metal
          There was a video on youtube about the quality of the Barnet drive plates, think I will replace with OEM when the time comes
            I am using the oem
            does any one know if not doing the 3 plate mod does the wire retainer need to be put back in
              Originally posted by Mike383 View Post
              I am using the oem
              12:57 time stamp of video he says no, not used again.
                i just did the OEM clutch with barnett and upgraded stronger springs. it definitely is a harder pull at the hand, engages a little stiff, and is jerky in parking lots as aforementioned. but the trike will spin the tires on accel or decel . and it is not belt chirp. these tires are wide, with so little weight on them, can chirp easily, letting off gas, or braking. im ready to tow a trailer, just kidding
                  I have a new oil pump gear ( not sure what is in mine I have an 00 that mods were done when I got it ) and a Barnett clutch kit and gasket. I'm a little leery about changing it when I hear about slow speed friction zone type changes.
                  • Mike383
                    Mike383 commented
                    I went with factory clutch plates and did the 3 plate mod Friction zone did change a little bit but I don't think its too bad with the Barnett pressure plate
                Started by coolalexrex, 2 days ago
                Started by Hank1988, 01-21-2021, 09:23 AM
                Last Post Va. 63 Roadie
                186 responses
                Started by Jclevesque, 5 hours ago
                Newb by bbf
                Started by bbf, 3 days ago
                Started by HMWREKR, 1 week ago
                Last Post hoytcanon
                Started by Sasquatch, 1 week ago
                Last Post Sasquatch
                Started by TexFer, 3 days ago
                Last Post bbf
                by bbf
                Started by Dwizzle6123, 1 day ago
                Last Post bbf
                by bbf
                Started by Sharpman66, 21 hours ago
                Started by Robmrtrct, 1 day ago
                Last Post BrokenWheel
                Last Post BubbaKahuna
                Started by TorontoRoadie, 1 week ago
                Started by Wolfman, 2 days ago
                112 responses
                Started by Shores, 6 days ago
                Started by mariner3302, 10-22-2020, 02:16 PM
