Okay new to me trike 1600 2000 year seems like the clutch is slipping at the upper end, weird because when it's cold if I let off on the gas the rear wheels will chirp when they slow down . This is the one I replaced the lifters and I put in the red gooey stuff and the extra zinc, but have since done an oil change. I did get a hold of an updated oil pump drive gear and I see that that's right under the clutch correct? So what do I do take it apart inspect and then order parts. I'm guessing I need a new gasket. I also was going through my crap and I found a brand new 1600 intake, I guess I should Port that with the Dremel. The last time I did that was like a long time ago and I used some kind of sealant on the o-rings, the clymers just says to use Grease. . I haven't done a clutch since 1970 something. Also I got all the stuff I need to do the oil pressure gauge on the left hand side I got the liquid filled gauge I have the why shaped oil line and stainless steel compression fitting. I still use the oil supply Port on the bottom left hand side of the motor behind the shifter?
Started by Madmichaeld, 1 hour ago
by Jclevesque
42 minutes ago
Started by Jaybo, 5 days ago
52 minutes ago
Started by AZRoadie, 1 day ago
by Chromepony
1 hour ago
Started by $arleysSuck, 2 hours ago
Started by Peterboro Pete, 1 day ago
by Chromepony
1 hour ago
by Chromepony
1 hour ago
Started by AZRoadie, 1 week ago
by AZRoadie
2 hours ago
Started by Shores, 6 hours ago
by moose
5 hours ago
Started by Jinro, 10 hours ago
by gr86ss
5 hours ago
by Ironman
9 hours ago
Started by MikeyC, 1 week ago
19 hours ago
Started by NthernLgts, 3 days ago
by NthernLgts
21 hours ago
Started by BrokenWheel, 23 hours ago
by BrokenWheel
21 hours ago
Started by Jeffw, 1 week ago
by Jeffw
22 hours ago
Started by zert800, 1 week ago
by SbTx_Rider
22 hours ago
Started by Tsilk87, 1 day ago
Odd
by Kroyleahcim
Started by Kroyleahcim, 3 days ago
by Kroyleahcim
Started by Doc_V, 09-23-2020, 02:48 AM
89 responses
