05 roadstar 1700 will turn over but wont start.when key is turned on gauges will sweep but no clicking noise like it use too. I'm thinking fuel pump relay. Any suggestions?
Fuel relay
There is no fuel pump relay persay , the starting system cutoff relay under the right side cover handle's quite a few things, its has a 12 pin connector and all the starting safety's are controlled by it ,side stand switch, clutch switch, neutral switch, starter relay , fuel pump. The fuel pump is not to hard to get at , i would test there first and see if the pump is actually getting power and just not turning, could very well be a stuck pump
Originally posted by brianmac View PostOh and when you start it, pull the choke but do not open the throttle at all until it fires up, or it gets too much air
- 1 like
if your RS dont start on 1st, rarely a 2nd momentary click of the starter, somethings wrong. now i live in south, dont get colder than 30 F, but just have to pull choke out more and duration more when shes that cold., also, you dont want to be overcranking that beast with 2 huge jugs for too long either, the electric motor will lose the battle against the compression/gasoline motor.
Started by MikeyC, 01-11-2021, 12:44 PM
by YamaDave
4 hours ago
Started by Roadstarkazoo, 2 days ago
by mlharper
4 hours ago
91 responses
5 hours ago
Started by tyates007, 6 hours ago
5 hours ago
Started by MikeyC, 4 days ago
5 hours ago
5 hours ago
by scotcher65
6 hours ago
Won’t start
by MRH
Started by MRH, 1 day ago
by scotcher65
6 hours ago
172 responses
7 hours ago
Started by Sasquatch, 7 hours ago
by DEEPHATE
7 hours ago
Started by LDofDC, 22 hours ago
by Bikerron
8 hours ago
Started by luff_tackle, 17 hours ago
by SbTx_Rider
10 hours ago
Started by TorontoRoadie, 2 weeks ago
Started by JC32, 4 days ago
by Chromepony
13 hours ago
Started by vicburn454, 4 weeks ago
by moose
13 hours ago
Started by rdpickard, 1 week ago
by Sharpman66
18 hours ago
by Sharpman66
18 hours ago
1,054 responses
Started by Airlordd1, 4 days ago
