Hello all! I hope everyone had an enjoyable Christmas and New Years. Here in Canada we hibernate in our homes and are unable to ride until April/May. Unfortunately, last summer i lost 5th gear on a trip through Northern Ontario. It failed at the 200km point into a 1000km trip. She got me 800km home in 4th gear. I strained the oil and nothing come out. Now its time to repair it. I'm using a Clymer service manual and its going well. Step by step instructions and very detailed. Once i get into the transmission and find out whats broken, i'm rebuilding with new rings, gaskets and a Barnett clutch. I noticed the cylinder walls have some scoring and plan on sending them out for a hone. I also noticed a considerable amount of carbon build up on top of the pistons. Does anybody have some suggestions that i should be replacing or inspecting? Cheers!
2003/1600 Engine Disassemble
Can you show a picture of that scoring, I've never seen it happen on a 4 stroke with ceramic composite coated cylinders. 2 strokes yes but never a 4 stroke, my 650 had 70,000 miles and i could still see some factory honing marks in the cylinders when i replaced 5th gear. I had the 30,000 roadstar apart last year and those cylinders looked brand new, if the ceramic got scored i can only imagine what the piston skirts look like
- 1 like
I used nylon bottle brushes and solvents to remove carbon from the pistons and combustion chambers on mine, there was so much of it the engine had some spark knock and when trying to start it hot it sounded like the timing was too far advanced, after cleaning it up it never did that again, there was so much carbon i couldn't see the valve relief in the pistons on mine
- 1 like
Don't Hone cylinders.... Clean with rag and brake cleaner
If using Barnett pressure plate makensure to use only OEM Yamaha clutch disc's and steels (not Barnett clutch disc's and steels)... Also good idea to get rid of the wire and half clutch disc behind it and replace will a full size one.
Can carefully scrape carbon deposits (get big hunksnoff
Loosing 5th gear is very unusual.... What all happened? What oil has been used? What mileage on bike? How long have you owned bike?LET'S RIDE
- 1 like
Originally posted by Pauli466 View PostCan you show a picture of that scoring, I've never seen it happen on a 4 stroke with ceramic composite coated cylinders. 2 strokes yes but never a 4 stroke, my 650 had 70,000 miles and i could still see some factory honing marks in the cylinders when i replaced 5th gear. I had the 30,000 roadstar apart last year and those cylinders looked brand new, if the ceramic got scored i can only imagine what the piston skirts look like"It's not the destination...it's the ride"
Originally posted by Lug Nut View PostDon't Hone cylinders.... Clean with rag and cleaner
Loosing 5th gear is very unusual.... What all happened? What oil has been used? What mileage on bike? How long have you owned bike?"It's not the destination...it's the ride"
Originally posted by Shores View PostDo not hone the cylinders! They are coated with a ceramic type material that is bulletproof and contributes to the longevity of the engine. Make sure you have the upgraded oil pump gear."It's not the destination...it's the ride"
Originally posted by Sharpman66 View Post
I found out its not scoring. Just up and down marks. Can't feel it with a finger nail.
- 1 like
Odd
by Kroyleahcim
Started by Kroyleahcim, 1 hour ago
59 minutes ago
Started by Cheapamanche, 8 hours ago
by Cheapamanche
1 hour ago
Started by BC1955, 1 week ago
by gr86ss
3 hours ago
Started by Ironman, 3 days ago
3 hours ago
Started by Jaybo, 2 days ago
3 hours ago
Started by puppyboysdad, 1 day ago
by gr86ss
4 hours ago
by EP Roadie
4 hours ago
Started by boomerA, 2 days ago
by Tykes_Place
5 hours ago
Started by wtucker, 10 hours ago
by Bikerron
9 hours ago
Started by LDofDC, 12-23-2020, 12:17 PM
123 responses
10 hours ago
Started by NthernLgts, 1 day ago
by Horsehammerr
13 hours ago
19 hours ago
20 hours ago
Started by Shores, 02-21-2018, 08:37 PM
23 hours ago
Started by Shores, 02-21-2018, 09:16 PM
43 responses
23 hours ago
Started by zert800, 5 days ago
by Chromepony
Started by Jeffw, 4 days ago
Started by Lug Nut, 01-16-2021, 12:21 PM
Started by choppa, 01-19-2021, 10:07 AM
Started by MikeyC, 1 week ago
