Any membersnin/near Calumet OK?
  • Any membersnin/near Calumet OK?
    Any RSC members in/near Calumet OK? Hopefully buying some bags/tourpack possibly but if he doesn't want to mess with shipping maybe a member who can pick up if they would be interested. These are Royal Star Venture tourpack and saddle bags with brackets/mounts and outer saddlebag guards. Complete set.
    I'm checking into Greyhound for shipping if he agrees to it. Otherwise would see if any member here wanted a complete tourpack/saddlebag setup for their Road Star from a 1999 RSV. Would be the ultimate touring setup for a Road Star honestly....
    That's about 100 miles from my old hometown though I had never heard of it.
      The parts are your color.
        I would keep for a future build. I'm happy with purple bike as is... If I can get a good deal on all this stuff it will be on my shelf for later!
          IMHO these bags are the best looking and functional for our Roadstars. Glad I have a set.
            So do the bags and trunk mount directly to the roadstars or is there modifications that have to be made. I want to turn my into a bagger, I would need a trunk at the very lease.
              Require modifications for sure
                Very little modifications are to be made. Most is near direct bolt on but depends on your exhaust configuration.
                  Here I am using the all the stock mounting holes except the lower passenger foot peg location needs a flat drilled plate. All this requires that you use lower than stock dual exhaust.Front bag mount requires a fabbed bracket also.
                    Your stock turn signal bar would also need to be shimmed away from the fender a bit, I opted for this laydown plate and turns from Kuryakin.
                    There are many ways to skin this cat as many others have done it in ways to suit the equipment they had to work with, maybe some others will share also, the old moderator Kia or was it Kai comes to mind.
                  I was able to use the Yamaha trunk mount also because I used all the RSV mounting bracket for the RSV bags. This is not a cheap mod.
                    There is a very good Yamaha mechanic I know in Ft. Wayne that adaoeted complete RSV setup to his Road Star... Made/welded all brackets... Looks factory as can be.. Very nicely done.
                      The rear signal bar only needs to be moved back about an inch. I used a small steel plate to bolt in stock location and drilled 1” further back for bar. Like Mort said mounting points need to be figured out up front. Fender mounts are the same. For front mounts I used the Geno lowering bag brackets it actually worked exactly to mount.
                        Signal bar bracket relocate plate. Front left side mount needs to be cut to clear swingarm and belt guard.
                          Thanks for posting that detail sir.
                        • Jclevesque
                          Jclevesque commented
                          I think I got some clarifications from Tykes on this. Rphazen was the one who fabbed up some brackets from scratch. Was nicely done!
                      Started by Bip_Bip, 1 day ago
                      Last Post Bip_Bip
                      by Bip_Bip
                      Started by roadiemort, 08-22-2020, 04:09 AM
                      273 responses
                      Started by Michael72, 09-02-2020, 11:48 AM
                      Started by Slammed&Cammed, 1 week ago
                      Started by YZ18, 3 days ago
                      Started by mariner3302, 10-22-2020, 03:16 PM
                      Started by brianmac, 1 week ago
                      53 responses
                      Started by Shores, 6 days ago
                      Started by SbTx_Rider, 6 days ago
                      Last Post LeLimoMan
                      Started by Lug Nut, 10-18-2020, 05:32 PM
                      Last Post LeLimoMan
