Speedo lightbulb
  • Speedo lightbulb
    So most of my speedo lightbulbs are out. I opened up gauge and didn't see any bulbs. Where are they and what kind are they?
    P.S. Running to the store to get some burritos.
    I used Honda car clock bulb 35505-s84-n01. You have to take the speedo cluster off of the under side of the dash to get to them. Not hard at all.
    edit: mine is a 2003
      Hmmm, I did open up the speedo cluster to the inside and didn't see anything that looked like a bulb? I might be blind. Got a picture?
        Some put led strip around the circumference under the glass and forgo the bulbs, no hot spots from the bulbs.
          https://www.partzilla.com/catalog/ya...kUjFJwsOvlUYVs
            This diagram shows a wire going to each light. I think Mike's bike has the lights clipped onto the circuit board.
          T3 I Believe is the size
            Mike, the lights are very small. On the back of the circuit board, you should see 4 brown twist lock style bulb holders. Turning them 1/4 turn counterclockwise unlocks them then you pull them up.
            I've seen the twist locks black as well.
              Ah, I didn't pull the circuit board up, was afraid to damage it. I thought they couldn't possibly be under there.
                Mike, you do know that you can also adjust the brightness of the dash lights, right? Are you sure they are burned out or just dimmed?
                  I did not know that, how do you do that.
                    On my 08, it’s done using the Select and Reset buttons on the right handlebar. DK if older models have it. Check your users manual.
                  • MikeyC
                    MikeyC commented
                    Hmmm, we don't have select and reset buttons on the right handlebar so it's probably only on newer models.
                  Shores, I had mentioned that one time as well. But I believe that is only on the latter models (FI?) that use LEDs instead of traditional lamp bulbs.
                    I did not know that you could dim them, I will check, how do you do that? But I'm pretty sure they're out as there is one bright spot.
                      Я не верю твоей лжи ни на минуту, слишком смешно
                      What are you saying Mort?
                    Brad, I found your old post and got some part numbers.
                      Good to hear.
                    So I took that whole assembly apart and got it figured out and it looks like I need the dorman bulb. Didn't realize they came out from the back side. Got it figured now.
                      But you do on the dash don’t you?
                      • MikeyC
                        MikeyC commented
                        oh yes i have 2 buttons on the dash
                      OK , How do you adjust Dash Light brightness with the Odometer and Clock set buttons on our older models ?
                        You'd have to look in a manual but I'm not sure you can on the older ones. The newer bikes with the select buttons on the right bar controls you can.
                      I put the led strip in mine. No more hotspots and a lot brighter.
                      the original bulbs are in little plastic holders that twist into the back of the circuit board. 1600’s are T3’s, 1700’s are T4’s I believe if you’re doing just bulbs. The pictures I’ve seen though of led bulb replacements create massive hot spots. Looks bad I think. The strip light is even lighting all around.
                      • FDRUCaptain
                        FDRUCaptain commented
                        It’s not bad for me. The visor helps a ton. But it makes it so easy at a quick glance to look and see clearly.
                      • Ironman
                        Ironman commented
                        Can you share a link for that LED strip? Thanks
                      • FDRUCaptain
                        It’s an Alpena brand light strip. Same ones that autozone or Walmart has.
                      Thanks! FDRUCaptain
                        do we have to remove the speedo/fuel needles from their posts to access these bulbs? if so how?
                          “I don't believe your lies for a minute, it's too funny.”
                          Started by EnergyGuy, 09-23-2021, 03:38 PM
                          Started by suemanda, 2 hours ago
                          Started by Dr. D, 2 weeks ago
                          Last Post Dr. D
                          by Dr. D
                          Started by Judd, 20 hours ago
                          Last Post SbTx_Rider
                          Started by Lug Nut, 16 hours ago
                          Started by Tykes_Place, 1 week ago
                          Started by Kmartcivic, 10-18-2021, 02:50 PM
                          Started by Nickgindy, 4 days ago
                          Last Post Jimmy C
                          by Jimmy C
                          Started by Jimmy C, 1 week ago
                          Last Post Jimmy C
                          by Jimmy C
                          Started by ItBeMe, 2 days ago
                          Started by roadiemort, 10-13-2021, 05:06 PM
                          66 responses
                          Started by EnergyGuy, 5 days ago
                          Last Post EnergyGuy
                          Started by Sasquatch, 4 weeks ago
                          Last Post Sasquatch
                          Started by MidnightRide, 1 week ago
                          Started by MidnightRide, 6 days ago
