Spoke rim blew out
  • Spoke rim blew out
    So just like someone posted the other day happened today. So i have a 99. Will the spoke rear wheel from an 08 be a direct fit for my bike?
    Additionally, will Mike’s 99 cush hub and internal bearing fit my 2008 wheel?
      Read my post below.
    Okay so I don’t know if spoke wheel is the same as the cast wheel but I was talking with Lugnut about switching to the cast and he pointed this out.
    The only issue is the mushroom head the 1600 pulley roller bearing has.
    The 1700 pulley roller bearing doesnt have this built in spacer.
    Look at the hubs and see if they are different. Hope this helps
      On the diagrams I just looked at the clutch hub center and cush Drive dampeners are the same model numbers from 99 wire wheel and 2008 wire wheel. So I would assume you be good to go and just reuse your old pulley and belt
        In both cases mentioned above a bearing swap will be needed. In both cases just simply remove the bearings and spacer from the old one that you are removing and install those bearings in the new rim/hub.
        Shores you will only need to swap the hub bearings with your old ones from the 08
        MikeyC You will only have to swap out the bearings on the hub side of the wheel on your 99
        • MikeyC
          MikeyC commented
          Cool, thank you for the info
        How about some photos Mike? I’ve never heard of that happening.
          Look carefully and you can see the problem! He ran over a dice!
            Wow! What are the odds of that ever happening again.
            WOW that is about as odd of a thing as I've ever seen.I could almost understand something like that happening on a cast wheel that hit a giant pothole but on a steel wheel I don't get what could have happened to rip that rim apart.
              Never seen that on a steel wheel. Internal rusting?? Just a bad rim?
                Maybe fractured during tire change?
              I guess your OK. I bet it was a real task getting stopped without going down.
              • MikeyC
                MikeyC commented
                A friend was riding that bike as his bike had a front wheel bearing going out. He said,"oh, it was no big deal" but the marks on the pavement said he did an awesome job keeping it under control and up right. And he was 2 up.
                Damn that's scary MikeyC, glad he was able to keep it upright and everyone is ok.
              Hey Mike, since you said there were marks on the pavement I wonder if the tube failed and then riding it on the rim is what tore the rim versus the rim tearing first. Was he going straight or making a right or a left turn?
                He just came out of a right hand turn. You could see where the rim contacted the pavement on both sides then a big space then tire skid on the left and jump 5 ft to the right in about 3 ft distance then he stopped about 40 ft past that
                  Left side skid was about 2 ft long and right side skid was about 4 ft long
                    What brand tire? Just curious if it was the one brand that has had issues with tread separation.
                    • MikeyC
                      MikeyC commented
                      What brand had separation issues?
                      Metzler
                    Tire was a Continental WWW
                      The tire looks good except where the rim bit it a couple times
                        Ouch!
                          Wow that has to be a primary rubber problem for the secondary rim problem after it hit the ground I'm guessing
                            Wow
                            Started by tachtom, 2 hours ago
                            Started by Lug Nut, 3 hours ago
                            Started by mariner3302, 3 days ago
                            Started by Jokke75, 6 days ago
                            Started by Doc_V, 4 weeks ago
                            71 responses
                            Started by ItBeMe, 5 days ago
                            Last Post JimK
                            by JimK
                            Started by dennishiggins, 3 days ago
                            Started by Phix, 4 days ago
                            Started by Lucky, 1 week ago
                            Started by lowriderbob, 4 days ago
                            Started by lowriderbob, 3 days ago
                            215 responses
