New bike build
    Wow this is going to be a real cool bike, gonna watch this man at work, brilliant
    Sometimes it takes a whole tank of gas before i can think straight
      There's nothing to pick apart. You are an artist. Please write more. Nothing is too technical for this group. Is the frame TIG welded? What size wheels are you planning to use? Sprung seat? What will you use for a gas tank? Oil tank? Chain drive or belt? Are you working from a picture or a sketch or a set of prints, or what? Thanks for sharing.
        There is one thing that will be IMPOSSIBLE for you to do on this bike build. You will not be able to post too many pictures or tell us too much detail with all you are doing!
        Hoping that you consider that a challenge!
          That is wicked awesome. How did you determine your spring rate?
            Hi guy's
            To answer some of your questions the frame is 1.250 x .120 wall chromoly tube all tig welded,going to run 16" wheels on both ends with Avon MKII 500-16 tires,will be using an air ride seat,custome made fuel and oil tank,it is chain drive i have removed the transfer gear.I just bent up a set of handlebars from 1.250 x .120 wall tube with 1.00 ends for the controls i haven't tack them up yet so tell me what you guy's think.
            Thanks Dean
              Oooh super exciting. Welcome to the roadstar rigid family.
              • #27
                love the look of the frame... I want one!! can't wait to watch this build.
                • #28
                  Originally posted by JD64k View Post
                  Hi Guy's
                  I made a little more progress on the bike in the last few weeks,built a leaf spring front fork something i have wanted to do for a long time,all pieces are bent ,coped and mocked up and tacked and seems to function ok,doesnt look the same as the early Indians and HD's but i didn't want that just the function.So check it out,pick it apart if you see something that you do think will work let me know. Thanks Dean
                  Hello Dean, I've been following your build and have looked at your photos several times. Your skills are to say the least impressive. I would like to see a set of plans for your frame jig myself I have kept going back to your front suspension over and over again, maybe I am not seeing the photos correctly, it just seems to me the way the front wheel pivots on the fork, it will be pulling down on your spring, not pushing up on it. That will put all the pressure on your mounting plate. I guess the way I am seeing it the leaf spring is stacked upside down, the small one should be on the bottom with the intermediate length one in the middle and the main spring on top. Other wise as it is the main spring is doing all the work and the other 2 are just spacers.
                  Please correct me if I am seeing it wrong.
                  Rod
                    HotRod, I think your looking at it wrong.
                • #29
                  I thought the same as HotRod, but you are correct Duke. Check these out.
                  http://www.bing.com/images/search?vi...ndex=8&first=1
                  • #30
                    I can already tell this build is going to be bad ass!
                    • #31
                      Rod
                      Hi HotRod,
                      There are no real plans for the fixture it's something i put together that works for me,it is fully adjustable for wheel base and frame width also the aluminum clamps will handle from 1 1/2" od tube down to 1" by using the half shells in the clamps.i will try and put some pictures and dimensions together and post it.Also the leaf spring is just mounted for mockup it does pull down there are 2 more leafs that belong under the main leaf i just didn't put them in there yet.
                      Thanks for looking guy's,i'll keep the pic's and info coming as i go along.
                      Dean
                      • #32
                        Dean,
                        The handlebars look good but not on this build. They are too contemporary for a rigid with a leaf spring fork. In my opinion buck horns, apes, or even a drag bar would look great as long as they were mounted on risers. And {just my opinion} stay away from the "adjusting the hot water while sitting in the bath tub" riding position.
                        Keep the pictures coming. You have piqued a lot of interest here.
                        Chooch
                        • #33
                          Just want to add a little update,leaf spring fork is all welded up and ready to go,still working on the spring reversing the leafs and adding one.
                          • #34
                            Just want to give you guy's an update rear fender is mounted and strut's are made just need to make up a short sissy bar and shorten fender.I made three option's of the sissy bar wanted to ask which one you guy's would go with,these are bent up with welding wire and a little hard to see.
                            Thanks Dean
                              I like option #1 & #4.
                          • #35
                            Wow! Great thread! I do not know much about builds, but my guess the frame is a lot lighter, and the bike will go like stink due to power to weight. i would be curious as to the weight of the bike after it is built.
                            • #36
                              My pick would be pic 2. You do great work!
                              • #37
                                yea I like the taller one...........
                                • #38
                                  Yep,I like the taller one too.
                                  • #39
                                    I’m partial to the half round. Simple design.
                                    • #40
                                      The toll one.
                                      Started by AreikUSA, 2 minutes ago
                                      Last Post AreikUSA
                                      Started by Wildkarp, 5 days ago
                                      Last Post Wildkarp
                                      Started by flyinj, 4 hours ago
                                      Started by BubbaKahuna, 3 hours ago
                                      Last Post YZ18
                                      by YZ18
                                      Started by Rob in FL, 6 hours ago
                                      Last Post Rob in FL
                                      Started by Dick M, 1 day ago
                                      763 responses
                                      Started by Rob in FL, 8 hours ago
                                      Last Post Rob in FL
                                      Started by Doc_V, 2 hours ago
                                      Last Post Rob in FL
                                      Started by Mark_N, 1 week ago
                                      Last Post BubbaKahuna
                                      Started by Txulrich, 4 weeks ago
                                      95 responses
                                      Last Post Txulrich
                                      Started by Chefturner, 1 day ago
                                      Last Post SKWEARpeg
                                      Started by Messer2.0, 02-13-2018, 08:58 PM
                                      Last Post grigby
                                      by grigby
                                      Started by FDRUCaptain, 8 hours ago
                                      Last Post Deerkiller
                                      Started by Downey, 1 week ago
                                      Last Post 75kona
                                      by 75kona
                                      Started by 75kona, 5 hours ago
                                      Last Post 75kona
                                      by 75kona
                                      Started by slyguy, 6 days ago
                                      Last Post Txulrich
                                      Started by Carpetbagger, 20 hours ago
                                      Started by Coreyallen221991, 1 day ago
