What is the Ford model/part number for a replacement for starter solenoid
  • What is the Ford model/part number for a replacement for starter solenoid
    Thinking I would like this information just in case I'm stranded and can't find a replacement Yamaha part. Anyone know the precise Ford model number for shorter relay that will fit? Thanks.
    I'm not sure of the part number but mine is from a 1990 ford F150. I use the stock relay to activate the ford relay. The way I use it, it keeps the high amperage from going thru the stock relay. Only a few amps to activate the coil of the ford relay.
      So, see if I got this. The stock relay is wired as usual but instead of going to the starter those wires go to the ford relay then from the ford relay to the starter?
        yes but the wires don't have to be heavy battery cables. They just have to be a heavy enough gauge to handle a few amps. I used 10 ga but only because that is what I had handy. The OEM starter relay is activated by a ground wire from the starter button. The ford relay is activated by a power wire. That is why the oem is used to activate it. If you didn't want to use the oem relay to activate the ford relay any relay activated by the starter button (ground wire) would work.
      I thought there was a Ford relay that was an actual direct replacement. Maybe I was wrong?
        • MikeyC
          MikeyC commented
          Cool, thank you for the explanation.
        • brianmac
          brianmac commented
          Oh I love technical art
        Ron has it correct.
          You can get them with top posts, or side. Just depends where you want to mount it.
          Here’s Davej’s setup. The smaller wire (red) is to the hot side of the factory relay and the other (smallest) red wire runs from the other post back to the trigger post on the Ford relay.
          Im thinking the fused yellow wire is powering some accessory.
            OK... I see how that would work. I was under the (erroneous) impression Ford made a relay that was interchangeable with the factory one (in case you needed one and couldn't find an OEM one immediately)
              you have to do the conversion first then you are good forever.
                here is the stock relay that goes with the ford relay post that Ron put up. I used a 10 gauge wire to go from the battery to the relay to make sure there was enough power availability to power the rest of the bike. I only used a smaller gauge wire to activate the Ford relay. Click image for larger version
Name:	stock relay mod post.jpg
                  I assume you have the Ford relay bolted to something to ground it.
                  yes and I have a ground wire going to the bolt that holds it down.
                That's great info! Thanks for the share!
                "It's not the destination...it's the ride"
                • dna9656
                  dna9656 commented
                  So is the OEM part not up to the job? Why not dlete the OEM solenoid and just use the ford solenoid for the whole job?
                • Horsehammerr
                  Horsehammerr commented
                  My Question Exactly ^^^^^
                  As davej mentioned, your using positive to the Ford solenoid and the ground is the mounting. Our bikes use ground to activate the solenoid.
                You’ll still need the factory relay in place to feed all the bike’s electrics throught the 4 wire plug.
                  I got one off ebay for 5 bucks and stuck it in the tool pouch along with a used pulser coil i got for 10.00, gives me peace of mind when in rural areas, got a little bag of goodies under that seat that getting bigger every year
                  Started by lowriderbob, 2 days ago
                  Last Post lowriderbob
                  Started by Lucky, 6 days ago
                  Started by mariner3302, 1 day ago
                  Started by lowriderbob, 1 day ago
                  215 responses
                  Started by DEEPHATE, 5 days ago
                  Started by Jokke75, 5 days ago
                  Started by ItBeMe, 4 days ago
                  Started by Phix, 3 days ago
                  Started by dennishiggins, 1 day ago
                  Last Post dennishiggins
                  Started by ItBeMe, 3 days ago
                  1,023 responses
                  Started by D-Fresh, 3 days ago
                  Started by AR. Hillbilly, 4 days ago
