Replace main carburetor diaphragm?
  • Replace main carburetor diaphragm?
    As many on this forum have read, I've been chasing a problem with my '07 R*. After finally being advised on settings with the Speedstar needle my bike came with, I removed the cap on top of the carb to change the clip setting on the needle. I was quite surprised when I lifted the diaphragm to find a considerable amount of what looked like rubber powder. After examining the diaphragm and seeing no obvious holes, I cleaned the cavity out by spraying carb cleaner into it. My question is: is this normal, or is it a symptom of impending failure of the aforementioned piece of rubber?
    I've never ran across any rubber like your describing. Is the rubber powder on the top or bottom of the diaphragm? I can only think that it has came in from the air cleaner rubber connections or the intake manifold. Have you looked in the manifold, or the "carb to air box" connection?
      They cost 27 to replace. I replaced mine when I did my carb rebuild.
        The rubber was inside the carb body, under the diaphragm.I have never run across this before either.
          There is a filter for the air movement on the lower side of the diaphragm. The 90 degree 1/2" tube that's at the top of the carb should have a black hose fitting looking piece that is a filter. There should be a screen inside of it and can be cleaned. I'm pretty sure that's where your getting stuff in the lower part of the diaphragm area.
          Air has to move in and out of that chamber as the slide moves up and down, or your carb would be slow responding.
          • DEEPHATE
            DEEPHATE commented
            Is that were that little screen it the carb rebuild kit goes?
            No, not that I'm aware of. I don't think the screen is removable, you would just clean it with solvent.
          Are you referring to that 90 degree fitting that looks like it should have a hose connected to it?
          • Horsehammerr
            Horsehammerr commented
            That's the one .
            Yep, that's the one! You want air to move freely in and out of it.
        Started by Jon D, 4 days ago
        Last Post YZ18
        by YZ18
        Started by MikeyC, 1 day ago
        Started by GreenMachine, 1 day ago
        49 responses
        Last Post GreenMachine
        Last Post Brian Schenk
        Started by D-Fresh, 2 weeks ago
        Last Post GreasySam
        Started by GreasySam, 10-03-2019, 05:13 AM
        43 responses
        Last Post GreasySam
        Started by Scjpll, 1 day ago
        269 responses
        Started by Roadstarrider, 2 days ago
        Started by thunderace4, 23 hours ago
        Last Post thunderace4
        Started by Brian Schenk, 1 day ago
        Started by Jon D, 1 day ago
        Last Post Jon D
        by Jon D
