Rear brakes
  • Rear brakes
    Do I have to crack open the bleeder on the caliper to get all four pistons to retract? As I pushed I saw my reservoir raising ( it was low ) so I thought I was okay but I can't get all four pistons to stay put retracted enough to get my caliper back on with the new pads. I get two in the others extend.
    ​With enough beer you can do anything...D.Pate
    I'm about ready to give up. I've scratched my fender all to heck wrestling with it and having it slip out of my grip as I'm trying to make two hands do the job or three/four. I hated to introduce air into the system but I don't see another choice. It shouldn't take all day...
      leave the cap loose. turn the old pad around and use a C clamp to push on the pad to retract 2 pistons leave the clamp on it and do the same for the other 2 pistons the fuid should go back to the master cylinder. Remove the clamps and install the new pads. when it is all bolted back together push the pedal with short strokes until the pads come out to the rotor and pedal is hard.
        Got it. Cap off was the trick....wow. Thank you!
        Started by Tykes_Place, 15 hours ago
        Last Post Jon D
        by Jon D
        Started by Blackcloud12, 1 week ago
        Started by Jon D, 5 hours ago
        Started by hardone2get, 5 hours ago
        Started by Andrew, 02-25-2018, 09:53 AM
        Started by a_gunslinger, 1 week ago
        Last Post texasscott1
        Started by Squirts, 1 day ago
        Started by viper, 17 hours ago
        Started by Lyndon53, 1 day ago
        Started by J89k, 3 days ago
        314 responses
        Last Post catnaper2
        Started by Kevin Di, 3 days ago
        Last Post Kevin Di
        Started by Jaybo, 2 days ago
        Started by Overkill jones, 08-25-2018, 09:02 PM
        Started by 07 silverado, 1 week ago
        Last Post 07 silverado
        Started by Rick Fortner, 5 days ago
        Last Post Rick Fortner
