Problem today PLEASE Help
  • Problem today PLEASE Help
    So I was leaving work today and my bike wouldn't turn over. lights were bright, no problems starting this morning. checked battery connection everything was tight. Checked fuses and kill switch all ok. Tried to push start and not enough room. Kept trying the starter and finally 1 rev and it started. The entire way home something sounded funny. When I got home and shut it off the starter was running. Pulled the key starter still running. Hit the kill switch starter still running. Removed negative from battery and it shut down. Burned my finger and thumb on negative bolt. Both pos and neg terminals look scorched. Did my battery cause this or is it possibly a short somewhere? Or maybe something else? 2001 Roadstar Silverado
    You might have gotten the starter hot.... welded itself? I don't think what your describing is the "starter spin" problem
    (but here is the info https://wayback.archive-it.org/10073.../view/187/103/)
    Did you check/test/replace the starter relay?
      You need to replace the starter relay under the left side cover. It has welded itself together inside. You probably also trashed the battery cables. I can help with that. I make and sell upgraded battery cables. PM me if you would like to purchase a set. They are $45 shipped in the U.S.
        Unless you want to go through that again in the near future do not buy a cheap, aftermarket starter relay. They don’t last.
        Buy OEM. They are pricey, but there’s an obvious reason for that.
        Here is the part number for the one you need.
        4BH-81940-02-00
        Started by thunderace4, 1 minute ago
        Last Post thunderace4
        Started by MikeyC, 12 hours ago
        Started by Father Pobasturd, 20 hours ago
        Started by Brian Schenk, 3 hours ago
        Started by D-Fresh, 1 week ago
        Started by Jon D, 13 hours ago
        Last Post Jon D
        by Jon D
        Started by Roadstarrider, 1 day ago
        Last Post Roadstarrider
        Started by Scjpll, 4 hours ago
        Started by GreenMachine, 23 hours ago
        Started by Shores, 17 hours ago
        Started by scotcher65, 5 hours ago
        Started by Jon D, 3 days ago
        Started by Lug Nut, 22 hours ago
        57 responses
        Last Post TMK
        by TMK
