Just put a brand new battery on my 2000R*. Still barely turning over. I was getting the clickclickclick. Did the tap with a hammer. Does about a half turn. Grrr...
Starter Symptoms?
we have permanent magnet starters. A tap with a hammer is a bad idea with this type starter. Hitting it will most likely either break 1 of the magnets or break it free from where it is bonded to the starter case. If either of these 2 things happen you are pretty much screwed. If it just breaks free from the bonding you may get lucky and find an epoxy that will bond it back to the case. Why not just remove the starter and take it apart clean and inspect the brushes and brush plate? That is probably what it needs.Now you have to remove it to check the magnets.
- 1 like
The R/S starters are easy & inexpensive to rebuild.
Check out www.mrcycles.com .
they've got wholesale prices on OEM parts.
I rebuilt the starter on my '00 for about $60.00 (10 yrs. ago). Add a set of those fat battery/starter cables & your starter will nearly spin the motor out of the frame.I love the smell of smoked pork in the morning !
in the starter where the 12v pos lead goes thru housing, it attaches to a brass U shape brass conductor, that has the wires on ends and brushes on ends of the wires. its called brush holder? The OEM's crack at the 90 degree bends, often fall apart in your hand . I have replaced 2 sets of OEM's on 2 different bikes. one twice. the second time i used an aftermarketbrand that needed a little tweak to fit, despite being advertized to fit.., figuring they had a bad batch of them at Mitsubishi or whatever. if part is cracked you will not get full power to armature. it goes from ok, to failed starts once in a while, then click and maybe, then no start.
oh, and i keep a spare brush holder set in the saddlebag, along with fuel tubing for that day IF my pump dies.
Started by EnergyGuy, 1 day ago
25 minutes ago
Started by Smokescreens, 1 day ago
34 minutes ago
Started by roadiemort, 20 hours ago
4 hours ago
Started by Blackbeard, 1 week ago
by Blackbeard
5 hours ago
Started by Shores, 7 hours ago
7 hours ago
Started by MrSinister, 12-06-2020, 08:54 AM
by MrSinister
9 hours ago
Started by Dan58, 1 day ago
by EP Roadie
9 hours ago
Started by BrokenWheel, 1 day ago
by EP Roadie
10 hours ago
Started by Rick Fortner, 2 days ago
10 hours ago
Started by Pauli466, 20 hours ago
by Pauli466
20 hours ago
Started by AR. Hillbilly, 02-01-2020, 11:31 AM
171 responses
Started by LDofDC, 4 weeks ago
79 responses
by EnergyGuy
by BrokenWheel
Started by Hank1988, 2 days ago
by EP Roadie
Started by Jclevesque, 4 days ago
by jd750ace
by Tropicalrs
by EnergyGuy
by BubbaKahuna
